Generator Replacement 5.7L V8
Removal
Procedure
- Remove the accessory drive belt.
Refer to Drive
Belt Replacement in Engine Mechanical-5.7L.
- Raise and suitably support the
vehicle. Refer to Lifting
and Jacking the Vehicle in General Information.
- Remove the generator rear bracket
mounting bolt.
- Remove the generator mounting bolts.
- Disconnect the generator electrical
connector (3).
- Remove the generator from the
vehicle.
Installation
Procedure
- Install the generator electrical
connector.
- Connect the generator electrical
connector (3).
- Install the generator mounting
bolts. Tighten
Tighten
the generator mounting bolts to 50 N·m
(37 lb ft).
- Install the generator rear bracket
mounting bolt. Tighten
Tighten
the rear bracket mounting bolt to 25 N·m
(18 lb ft).
- Lower the vehicle
- Install the accessory drive belt.
Refer to Drive
